Yes I see what is wrong. On the output you see a small circle. That small circle is a symbol denoting that the output is inverted. So your circuit is XOR with inverted output. You may also se this on a input. The meaning is the same hereA simple truth table that I somehow screwed up:
I showed the truth tabel for this as follows, with x being my answers:
A B X
0 0 0
0 1 1
1 0 1
1 1 0
That looks sooooo right to me. Can someone explain where I went wrong?
Thank you
Exactly right. And yes, the bubble serves the same purpose as a not gate connected to the output or input. Same idea.Thank you for the replies.
Okay, I missed seeing that little circle, all I saw was the XOR gate. If I understand correctly, that little circle is basically a not gate, it inverts the output values.
So, instead of
A B X
0 0 0
0 1 1
1 0 1
1 1 0
The truth table should have been
A B X
0 0 1
0 1 0
1 0 0
1 1 1
Correct?
Yes, I do, thank you for your assistance.Exactly right. And yes, the bubble serves the same purpose as a not gate connected to the output or input. Same idea.
You seem to have it now![]()
Yes, I saw that right away as soon as I got this answer resolved. I still do have one outstanding question on the other post, would you mind taking a look? http://forum.allaboutcircuits.com/showthread.php?t=81290 Thanks again!And that is why you got the other answer wrong also.
It's what we're here forYes, I do, thank you for your assistance.![]()
