a quistion related to microelectronics
28,502
The voltage across each diode, assuming that they are normal silicon diodes with no special characteristics, will be 0.7 volts (One digit resolution) I do not interpret the voltage from the simulator notation so I will not guess at the current.
28,502
If one needs to be more precise in the calculation of the diodes, which will be a whole lot more complex because the currents will be a bit different. IN addition, as the voltage increases from zero, there will be changes in the equation as the diodes become biased into conduction.
So this is actually a rather nasty problem because of two dependent variables coming into play as the supply voltage changes.
