A question about LT3091
Rf300
Joined Apr 18, 2025
126
Read the datasheet! You can set the output voltage by varying the resistor at pin "SET" between 0 V and -32 V. Your input voltage has to be at least 0.3 V lower than the output voltage. This is the minimum dropout voltage. If your input voltage is lower, no problem. The regulator will always convert the product
|V_in-V_out|*I_out
into heat.
engr_david_ee
Joined Mar 10, 2023
364
|V_in-V_out|*I_out
into heat.
Thanks. I got it.
38,740
Below is the LTspice sim of the LT3091 with four different values for the voltage set resistor R1 (giving 2.5V, 5V, 7.5V, and 7.66V ), while increasing the current limit resistor R2 and reducing Rload to show an increase in current-limit with time (curved lines going from 0.4A to 1.25A limit):
The 7.66V output is limited by the dropout voltage of about 336mV for the Spice LT3091 model
Edit: Increased step voltage range to show dropout voltage.
eetech00
Joined Jun 8, 2013
4,724
Dropout can be as high as -525mV.
Min input voltage is -1.5v (but can be as high as -1.9v)
Min output voltage is Vin+Dropout = -1.9v + -0.525v = -2.425v to maintain regulation.
engr_david_ee
Joined Mar 10, 2023
364
I have looked at the datasheet again and understand that the resistor Rlim between pin ILIM and GND will set the output current limit.
The resistor Rset between pin SET and GND adjust the output voltage according to Table 1 of the datasheet.
engr_david_ee
Joined Mar 10, 2023
364
I am wondering if there exist any positive linear voltage regulator similar to LT3091 with adjustable current limit and adjustable output voltage ?
I know there exist several positive adjustable voltage regulators. Usually there are two external resistors that can set the output voltage level. How current limit can be added to such voltage regulators ?
engr_david_ee
Joined Mar 10, 2023
364
Just another question.
Is that possible to use digital controlled potentiometer operated by microcontroller or FPGA and use instead of fixed resistors at SET and ILIM pins to make it digitally controlled adjustable voltage linear regulator ?
38,740
Only if the voltage across the digipot does not exceed its supply voltage.
Yes, the voltage on the pot wiper would equal the output voltage, so the pot supply would need to be equal to the highest output voltage.
The input voltage could be used if the pot could tolerate that voltage (many are limited to 5.5V).
Here's an example that goes to 36V.
But note that it has a ±20% initial resistance tolerance, and just 8-bits of resolution.
Also note the polarity of the required digital control voltages.
Rf300
Joined Apr 18, 2025
126
This could be possible but you have to keep two things in mind:
1. The absolute value of a digi-pot can vary up to 20% (again: read the according datasheet) This tolerance will also be the tolerance of your output voltage.
2. This might not work with negative voltages unless you do a level shift maybe with optocouplers.
38,740
Here's a simple way to control the output voltage with a positive control voltage (Cntl) using an opto coupler:
But note that the output vs. input voltage is affected by the transfer ratio of the opto.
This could be essentially eliminated, along with the 1V input offset, by using a linear type opto that has two matched outputs (e.g. IL300) with feedback from one output to an op amp driver.
