A Problem in Audio Amplifier
Doloop
Joined Feb 5, 2015
10
Hi
I have a Audio Amplifier Model Jas 4000
this Amplifier have two output but have a output problem Signal.
#12
Hi
I have a Audio Amplifier Model Onkyo A-5
this Amplifier have two output but have a "on" light problem
Tomato
ScottWang
Joined Aug 23, 2012
7,509
do not joke:D
can help me someone
I can not speak very best to english
Nobody kidding for your english, my english also not so good, if you still don't understand what's going on, that's the feeling what we thought about your post, because not enough infos.
Doloop
Joined Feb 5, 2015
10
hi
ok
I do not know where you're going bad:)
I did not bother ;)
You can get a good source for fix audio amplifiers ? tnks
Is it only English speaking people that can fix audio amplifiers?
Sorry I can not speak better than this :Dtnks
bertus
Joined Apr 5, 2008
23,029
Can you describe the fault condition of the amplifier?
Is one or are both channels not working?
Is there a fault indicator?
Is there any documentation of the amplifier?
Doloop
Joined Feb 5, 2015
10
It is hard to describe the English language for me...
But the choice is not:oops:
this is Mixer & Amplifire
has two output
each output 300w
one output it is ok and has Audio signal in output
but one of the outputs has not Audio signal ...
I to use multimeter measured transistors Voltages
no Voltage any Transistor
I think the true power transistors work And the problem of the control Signal.:confused:
tnks.
bertus
Joined Apr 5, 2008
23,029
When one channel is working and one not, you can compare voltages between them.
Is it possible to post some sharp photos from the PCB?
