A little help with AC Sweep
borkoborko39
Joined Apr 16, 2017
Hi i have this scheme sheme2.PNG and i set AC Sweep to start frequency 1Hz, End frequency to 1000MHz, logarithmic decade 101.
I need to do Medium frequency voltage gain, Voltage gain factor Ku in db, Current gain KI in db. How do i find them?
Bordodynov
Joined May 20, 2015
3,432
Hi. Value R3 is bad. The transistor does not amplify.
Look at your simulator's voltage on the gate and on the drain.
The gate-source transition is biased in the forward direction!
Jony130
Joined Feb 17, 2009
5,601
You need to set AC value to 1 and next you need to run ACsweep analysis then probe the voltage across R6. And the voltage gain is simply the voltage you read across R6. For example if the simulation will show you 10V the gain is 10[V/V]. And to plot the current gain use I(R6)/ I(V2).
Also can you tell my where I can buy 1.06μF and 6.83μF capacitors ?? The resistor values are also not standard ones .
borkoborko39
Joined Apr 16, 2017
Okay i think i figured it out. Is this how the result is supposed to be?
Sheme
Medium Voltage Gain
Voltage Ku in Db
Voltage Ki in db
How do i find Kp in db? Db(W(R6)/W(V2))?
shteii01
Joined Feb 19, 2010
4,644
Do you need power in dB or dBm?
If I recall correctly, power is usually in dBm, but since I don't know your course... I am not sure which one of the two you need.
shteii01
Joined Feb 19, 2010
4,644
I don't think any of them are correct.
Your input signal is V2. Your output signal is voltage across R6. That is not what your graphs show.
The C1 and C3 capacitors are the DC Blocking Capacitors, they allow AC signals through, but block DC.
