Hello! I am new here... just needed some help and advice!
I recently purchased a 2D cell 10LED Torch from my local Tesco, and would like to convert it to a standard 9V battery. It currently runs at 2.0v, however, I would like to increase this. Obviously NOT to 9V! As such, I devided to wire in a 9V battery adapter and pop in a resistor. I was probably going to go for 3V, so I was wondering how I would calculate what kind of resistor I need? And indeed, what resistor DO I need?
It seems that it currently runs at 2V with the use of capacitors wired into the LED's circuit (I will get some pictures of this if it helps) - as D cells are 1.5, and it runs at 5, there is a capactior between the live wire and the LED's. So should I go for 2.5 from the battery so it is overall 3, or, would 3.5 probably be fine?
They are ultrabright LED's, and it seems that, looking online, most will take up to 3.5v.
