90 led's circuits
myosff
Joined Aug 18, 2013
6
dear all
i need full diagram circuits for 90 led's sheet led's 5 mm blue and white and power supply 12 v
many thanks
DerStrom8
Joined Feb 20, 2011
2,390
You're not making any sense. I am guessing you are not a native English speaker. In that case, I suggest you try translate.google.com. It might help you to better explain what you want, and help us to better understand you.
Matt
absf
Joined Dec 29, 2010
1,968
You have to tell us more about the LED. How many are blue and how many are white. How much current and voltage is required for each color of your LED......etc
Allen
33,325
And let's not forget that this is the HOMEWORK Help forum. You need to show what efforts YOU have made to at least attempt a solution for YOUR homework problem.
33,325
now i don't need any help
So, either you figured it out on your own once you decided to make the attemp -- which is a great thing; or you concluded that we weren't going to just do your work for you and gave up -- which is a great thing.
ScottWang
Joined Aug 23, 2012
7,509
If you want to light up the 90 LEDs, then you should doing as this:
12V/3.6V=3.333, 90V/3=30 strings, the power only has 12V, so you only can using 3 LEDs in a string, and then you have to calculate the limited resistor for LED current limitation.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
dear all
many thanks
Don't now what r u doing are u making light system??
anyway just make 4 or 3 led series with series resistance of 100/220ohm 1/4watt as per requirement of intensity.
and then connect all these series in parallel to 12v source...
33,325
How do you figure that the OP will be able to power 3 LEDs in series if they are using 12 V and each LED has a forward drop of 3.6 V?
At the requested intensity of 75 mA, a 100 Ω resistor will drop 7.5 V and dissipate well over 500 mW while a 220 Ω resistor will drop 16.5V and dissipate nearly 1.25W. So just where did you come up with the recommendation of using "100/220ohm 1/4watt" resistors?
With three LEDs in a string, the voltage that needs to be dropped across the current limiting resistor would be
Vdrop = 12 V - 3 x 3.6 V = 1.2 V
To do this at a current of 75 mA would require a 16 Ω resistor and would dissipate about 90 mW. This may work just fine, but small variations in the forward LED voltage or the supply voltage could move the actual current around by perhaps 50%. If that's acceptable, then this is probably the way to go.
But if the OP needs a more consistent and uniform current, it would probably be better to go to two LEDs in a string, meaning that the resistor would have to drop
Vdrop = 12 V - 2 x 4.6 V = 4.8 V
which would require a 64 Ω resistor (use a 62 Ω if you need it close or a 56 Ω or a 68 Ω if you can be a little loose) capable of dissipating 360 mW. So two 1/4 W 33 Ω resistors in series might be a way to go. With this, it is probably unlikely that the current will vary more than about 10% from the nominal value.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
OK, if there are 8 Led white in series with 220ohm at 1/2 or 1/4 watt resistor(in paraallel there are more than 1000's led) driving from 26V source is not giving good brightness, increasing voltage to 46V will damage the led?
33,325
What, on Earth, are you rambling about? Who said anything about 8 LEDs in series? Or thousands of LEDs? Or about 26 V sources? Or about 46 V sources?
Are you sure you are in the right thread on the right plane of existence?
