90 degree phase shifter design
AnalogKid
Joined Aug 1, 2013
12,284
Do we know anything about the input frequency rate of change within the band? Or a minimum rate of change at the output when responding to a step frequency change at the input?
ak
28,454
The "integrator/AGC scheme would be about 50 times more complex and be less reliable, cost more, and use a lot more power. PLUS it would need adjustments after being built.
38,871
Then what scheme that gives a 90° phase-shift with constant amplitude over a 5kHz to 50KHz range?
None that come to mind.
An integrator will give a constant phase-shift, and an AGC can be designed to have a constant amplitude based on a fixed reference voltage.
AnalogKid
Joined Aug 1, 2013
12,284
One dual opamp plus a JFET is 50 times more complex than a sinewave-in, sinewave-out phase-locked loop?
Nope.
Really - ? You know that transistors use less power than tubes, right?
Why? Other than output level, none that I can think of.
You make five comparative statements, so my question to all five is - compared to what? What technique, what approach, what topology, what circuit?
ak
28,454
Really, for the common applications, the choice has been to create both lead and lag 45 degrees phase shifts. AND IT IS ALWAYS A COMPROMISE. AND, I would point out that my visualization of an integrator plus an AGC system would be complex and need adjustment. Perhaps others can do it more simply.
AND the statements at the beginning of the thread seem a whole lot like a college level take-home test. Especially since there was no hint of any application.
So now, what I would do, is use the incoming sine wave to synchronize a direct digital synthesizer programmed for both sine and cosine generation. For waveform cleanup, variable band-pass filters
28,454
Nope.
ak
OK, your integrator is a lot simpler than what I was considering. Likewise your AGC scheme. Quite brilliant, really!! AK wins this one, folks!!!
28,454
With square waves and a PLL it is quite simple: The oscillator runs at 4X the input, and so there are rising and falling edges every 90 degrees in the dual FF doing the divide by four. Then use the square waves to synchronize four sine wave oscillators.
Ian0
Joined Aug 7, 2020
13,298
At some point it becomes simpler to start with an oscillator (Bubba, for instance) that make both sine and cosine waves.
AnalogKid
Joined Aug 1, 2013
12,284
. . . that have a constant amplitude over a 10-to-1 frequency range. Nothing complex about that.
Actually, that could be a handy thing for some other project - a circuit that synchronizes a sinewave oscillator to a 10:1 variable-frequency squarewave - without having t learn a programming language. I'd like to see that schematic.
ak
38,871
A differentiator needs fewer components than integrator, as it doesn't need anything to keep the DC voltage from drifting, and still gives the 90° phase shift. (see post #4)
It's one disadvantage is that it amplifies any high frequency noise and distortion, whereas the integrator does the opposite.
Ian0
Joined Aug 7, 2020
13,298
But does it make any difference overall? The overall system gain must be unity, so if the phase shift element has a gain which increases by 6dB/octave, then the AGC must have a gain characteristic that falls by 6dB/octave, and vice versa.
Maybe there might be more noise on the control input to the AGC, but VCAs are not the quietest of things at high frequency.
KeithWalker
Joined Jul 10, 2017
3,623
You are all probably wasting your time speculating on a possible solution. The TS did not bother to supply any more information and appears to have left the discussion.
28,454
This did seem like a college course question. For practical applications in real world systems the approach for several decades has been to deliver both 45 degree shifts leading and lagging, which is less demanding , evidently. Especially with real world signals such as voice for communications.
hoyyoth
Joined Mar 21, 2020
531
I don't have much information.The information I have is alreay shared.What I was told is first make circuit which can phase shift an incoming signal of frequency 5Khz to 50Khz,Amp 1V by 90.So I am planning to make a proto first.
28,454
At this point, with no more information, the concept of a sine/cosine PLL tracking the input and providing ONLY the 90 degree shifted input is what sounds reasonable. No adjustment in angle provided.
hoyyoth
Joined Mar 21, 2020
531
May I know ,Can I use any PLL IC for this application.
If you can show me the circuit,it is well and good
