Hello, I'm new
I'm having trouble with the 74ls08:
So here's what I get:
When I connect the power to pin 14 (using resistor voltage divider because I use a 9V battery and I need 5V for this one) and ground pin number 7 I get 4V from pins number 11, 8, 3 and 6 without any input to all 4 gates!.
when I connect the power to lets say pin number 13 and 12 I still get 4V from pin 11, when I ground any of the input pins i get 0V from output (for example pin 13-grounded, pin 12 - 5V, pin 11 - 0V) when i ground both inputs i still get 0V as output. Please help.
here's what says on the ic: HD74LS08P OC16
