74AHCT125 Quad buffer/line driver question.
Bod
Joined Sep 18, 2016
317
I have a circuit that produces 4 different outputs between the range of 0-5V, coming from audio biased at 2.5V (the circuits are a high + low pass filter, positive + negative peak detector)
The micro controller I am using is an ESP32. It can only take up to 3.3V on the input (3.6 if you want to push it). Since my outputs are often greater than 3.3V, it will fry the board.
That means I needed a way to lower the voltage from 5 to 3.3. One of my ideas was to use something a logic level convertor like this: 12009-07.jpg
It takes 5V and makes it 3.3V, or 3.3V -> 5V. I am already using one for the light strips connected to my ESP32. The problem is, they are using transistors, which I believe won't switch fast enough for audio. Since my output is a range (0-5V) not just a constant 5V, I don't know what the output would be if the input was something like 4.2V.
Anyway, I did some more looking around and came across the 74AHCT125 Adafruit chip. It is 3-state quad buffer/line driver. The datasheet describes it as a "a high-speed Si-gate CMOS device". It says it's 'high-speed', so I'm hoping it will work with audio.
In the datasheet under section 9 - static characteristics, it provides a good table:
I don't really understand it though. Unlike the logic level convertor, there are no low/high voltage pins, just input and output pins. If I were to put 2.0V in, how would it know whether I wanted more than 2V out or less than 2V out?
Is anyone able to provide more insight into this chip? Or even better, a way to covert a range of 0-5V to a range of 0-3.3.
dl324
Joined Mar 30, 2015
18,478
The device referenced is a tri-state buffer. When enabled, the output will be the same logic level as the input. It doesn't do level shifting. Like most CMOS devices, it has diode clamps on the input.
At audio frequencies, you could use a voltage divider. Or you could use CD4050 which are designed to do high voltage to low voltage conversion (they removed the clamp to the positive supply).
Bod
Joined Sep 18, 2016
317
Thanks for the reply. Honestly, the voltage divider is definitely the best way to go. I was trying to think about any reason it would not work, but as long as the input voltage is clamped between 0 and 5, if I halve it, it will never go above 2.5V anyway.
ericgibbs
Joined Jan 29, 2010
21,601
hi Bod,
I use the level shifters as shown in your picture, they work OK.
Using as level shifters at 20MHz on SPI.
If you solder a 78L03.3, TO92 across the top of that PCB, you can create 3.3V from 5V for additional 3.3V devices.
E
Edited 78L
Bod
Joined Sep 18, 2016
317
hi Bod,
If you solder a 78L05, TO92 across the top of that PCB, you can create 3.3V from 5V for additional 3.3V devices.
E
That's good to know. I think I should be able to try it out. Im not sure how much voltage my function gen puts out.
Even if it works for frequency, will it work for the full voltage range?
I.E on the level shifter, a 0V input will be a 0V output and a 5V input will be a 3.3V output. But what about a 2.3V input. Will the output be 0V or will it be 1.3V? (1.3 is the actual voltage you will get out when you put in 2.3, providing the board allows that)
Chris65536
Joined Nov 11, 2019
270
I don't think digital buffers or level shifters are the right choice for your analog signals. Simple resistor voltage dividers would be better.
Analog Ground
Joined Apr 24, 2019
460
However, you convert the signal, the minimum input voltage for a logic high level on the EPM32 is 75% of the power supply voltage. So, 75% of 3.3 V is 2.475. You mention 2.5V but this is too close to the minimum high level. I suggest going above that to give some margin. Like 3V or more.
OBW0549
Joined Mar 2, 2015
3,565
Are his signals digital? From the original post, I thought it was analog signals going to the A/D converter inputs.
I'm getting an impression that the TS may not be totally clear on the difference between analog and digital signals, and what his various buffer/level translator solutions will do to his signal. He starts out clearly identifying his signal as analog, specifically "audio biased at 2.5V" but then goes into discussion of logic level converters and the 74AHCT125 chip. He may not be aware that these devices do not produce a voltage output which is a linear function of input voltage and that instead, they produce a logic output in response to a logic input.
I'm at a loss as to what he's trying to do here.
eetech00
Joined Jun 8, 2013
4,733
That means I needed a way to lower the voltage from 5 to 3.3. One of my ideas was to use something a logic level convertor like this: View attachment 197928
If I understand correctly, you have an audio signal in the range of 0-5 you want to scale to 0-3.3v?
Why not use an opamp with a voltage divider to scale the audio into the ESP32?
Or, are you needing to scale a DC voltage (output of peak detector)?
You may, instead, need to use level detectors (comparators).
eT
Bod
Joined Sep 18, 2016
317
Well, unfortunately, it seems my reply didn't get posted, so I'll summarise what I said.
To put it simply, I did in fact get confused between digital and analog. I did end up just going with a voltage divider.
Sorry to everyone who was waiting for a response!
