70TPS12 Thyristor - Help!
Irving
Joined Jan 30, 2016
5,195
What value resistor in your gate circuits? For that high-power SCR you are probably not supplying enough gate current to turn it on, nor is there enough anode current with just an LED on 5v for it to latch on.
mangoelectrics
Joined Mar 24, 2025
23
Thanks for your reply.
If you look through the other forum, you will see that I have tried with numerous different resistors and also tried to use a dc motor on it.
Also I have just tried to put a 12v dc motor connected to 12v - then other end connected to K of thyristor and 12v + connected to A of thyristor then 3.3V dc into Gate of thyristor. Still does not work.
Thanks again, and any ideas would be much appreciated!
mangoelectrics
Joined Mar 24, 2025
23
Thanks, the circuit above works!
How can I run 400V DC through the thyristor using that circuit above?
Thanks again, we seem to be getting somewhere!
schmitt trigger
Joined Jul 12, 2010
2,215
Did you read the image that you posted? That thyristor could require up to 270 mA to trigger. The trigger supply must be able to source that much current.
mangoelectrics
Joined Mar 24, 2025
23
How do you plan to switch it off once it has latched on ?
Les.
Thanks for your question. Once it latches on, all that happens is the capacitors will fully empty and then it should switch off. Once it is off, I can then recharge the capacitors and cycle again.
I have not yet tested the new circuit, but will also require a diode to stop back current from blowing the thyristor.
Does this look good? If so, what size diode do you think I would require to stop the back current? I have put in two diodes.
Thanks all!
Danko
Joined Nov 22, 2017
2,233
Ive just tried this out, but it does not work. For testing purposes I tried it with 12v as the 400V with a 12V dc motor as the LOAD and the thyristor does not trigger.
Do you know what could cause this?
It may be because of current interrupting in brushes system.
Connect incandescent 12 V bulb parallel to motor,
and see how it will works.
