7 Segment with transistors array
Omais Ahmed
Joined Oct 4, 2015
35
Hello Everyone,
i'm newbie in electronics.
I'm using below schematic to drive 3 digit common cathode 7 segment. udn2891 chip is expensive. so i'm using transistors array.
I want to know will the below schematic work?
A reminder when programming is that you have to implement inter-digit blanking. You have to turn each display completely off for a small amount of time before you set the seven segments of the next display otherwise you end up with a sort of ghosting between segments.
Omais Ahmed
Joined Oct 4, 2015
35
Thanks KeepItSimpleStupid. you are right.
dl324
Joined Mar 30, 2015
18,453
Since you're new, let me give you some advice.
We have a strong preference for the flow in schematics to be primarily from left-to-right and top-to-bottom, with unnecessary wire jogs and scenic routing avoided. When using signal buses, it's customary to show signals entering and leaving the bus. You should also be consistent. If you use a connection dot on one 'T', you should use dots on all of them.
If you add current limiting resistors to the bases of Q1-3, it could work. While it's unlikely that the shift register could damage the BE junctions or the shift register, it's unsightly.
To be more certain the circuit will work, you need to show all connections.
