7-Seg 4-Digit LED display pinout
abuhafss
Joined Aug 17, 2010
318
Hi
I shall be grateful if anybody can help me out with the pinout of 7-Segment 4-Digit LED display bearing part number CSQ-4246G 05. I tried to google it but could not find much information.
abuhafss
Joined Aug 17, 2010
318
ericgibbs
Joined Jan 29, 2010
21,489
hi,
Thats a good question.
Both the diagram and your photo images show 13 pins.
Usually D0 is the least significant Digit Enable
I would suggest you build a simple test jig, as per your last diagram, you should be able to identify the DOV function.
E
abuhafss
Joined Aug 17, 2010
318
hi,
E
I already did the test. Here are findings for my displays, maybe helpful for somebody.
It's a COMMON-ANODE module
Pin 1 - DOV
Pin 2 - D1
Pin 3 - D2
Pin 4 - D3
Pin 5 - D4
Pin 6 - Semi-colon*
Pin 7 - G
Pin 8 - F
Pin 9 - E
Pin 10 - D
Pin 11 - C
Pin 12 - B
Pin 13 - A
* Upper dot of the semi-colon activates with D3 and lower one with D4
abuhafss
Joined Aug 17, 2010
318
What did your testing show when you were testing the DOV pin? It appears to be treated like a common anode in the schematic.
Frankly speaking, I could not solve the D0V pin.
I could not find any LED activity while powering it thru a resistor and connecting the ground to the remaining pins alternately.
I would be glad to hear about it for the sake knowledge.
dl324
Joined Mar 30, 2015
18,409
If the pin doesn't do anything, I'd just ignore it.
If you can't stand not knowing, search for the datasheet (I did for a few minutes and it wasn't worth more time), or try contacting the manufacturer.
It's always possible that it was a customized part for a particular manufacturer.
I have some dual digit seven segment displays installed on a small PCB. It turned out it was a custom part that is actually only a digit and a half (most significant digit can only display 1).
