Audioguru has shown the simplest and the best way of varying the input signal level to the LM386 power amp IC.
However, reading between the lines I think you are talking about using a variable control voltage to change the amplitude of the oscillator, which is different altogether. For that you will have to use a VCA (voltage controlled amplifier). I believe we discussed that option in an earlier part of this thread, although in that context we were talking about using a voltage controlled waveform to modulate the oscillator?
Is that what you are intending?
