5V Power supply(AC to DC converter )
AlbertHall
Joined Jun 4, 2014
12,663
I need the clarification of output side of the transformer
Transformer output one end (PWM signal) connected to CLC filter afer CLC filter we will get pure Dc output?
what purpose of Transformer other end connected Schottky diode cathode and snubber circuit?
On the secondary side there is also a rectifier diode. The output will not be pure DC, it cannot be, it will always have some ripple and some switching spikes. The filter on the output reduces this to some level acceptable for the circuit it was intended to power.
On the primary side, when the MOSFET switches off the drain voltage will rise above the supply voltage due to the inductive back emf from the transformer. The snubber circuit is there to protect the MOSFET from excessive voltage while wasting as little power as possible.
Dodgydave
Joined Jun 22, 2012
11,395
It's a Switchmode psu with opto-coupler feedback for voltage monitoring, and output isolation. the voltage is regulated using a Tl431 zener and opto-coupler, standard equipment on most switchmode psus.
Baskaran Manoharan
Joined Apr 18, 2016
5
secondary side Rectifying diode required?
