Using LTspice, I keep seeing this 5Hz current resonance through C1 and FET. Amplitude changes if I change the FET model. 220uF would need something around 4.6mH to get 5Hz, so where is this current ripple coming from? The voltage on Drain stays at 20v the whole time. Is this just a LTspice issue? There's no resonance if I remove uic directive.
