5Hz resonance ?
DC_Kid
Joined Feb 25, 2008
1,253
Using LTspice, I keep seeing this 5Hz current resonance through C1 and FET. Amplitude changes if I change the FET model. 220uF would need something around 4.6mH to get 5Hz, so where is this current ripple coming from? The voltage on Drain stays at 20v the whole time. Is this just a LTspice issue? There's no resonance if I remove uic directive.
DC_Kid
Joined Feb 25, 2008
1,253
Not I(V1), probe I(M1).
See attached.
But if I charge the gate slowly, I see where the 5Hz cuts to zero as the FET goes full on. LTspice does not appear to simulate the linear region. Also, using the 'startup' directive changes things.
