555 Timer's SR Flip Flop with OP Amps
IHideKeys
Joined Oct 22, 2016
How can I build a SR flip flop using op amps? (for a hand made 555 timer) Transistors may be used. I was thinking of using a hysteric op-amp and putting a schmitt trigger on the input of comparator 2. However, my solution fails in simulation. Here's my current circuit.
It works with the LTSpice model of a SR Flip-Flop so I know everything else is working as desired.
AnalogKid
Joined Aug 1, 2013
12,266
Here is a 1-opamp flipflop. Pulling either the set or reset inputs up to 12 V will cause action. Alternatively, you can ignore either input and use the other one for both set and reset. for example, pulling set up to 12 V sets the output to near 12 V, and pulling the set input down to GND sets the output near GND
ak
