555 timer
umer0314
Joined Jul 29, 2009
29
Do you know how can I explain the circuit we just built in detail. I want to explain the four timers separately ( U1, U2, U3, U4) and what each one is doing with the capacitors, and resistors attached to it. Can you help me explain the circuit so I can explain it to my professor.
Thank you!
Wendy
Joined Mar 24, 2008
23,869
Did you look at that data sheet on post #24? That is the block components.
If you look at my 555 experiments you can find examples and explinations for the various configurations in my Theory of Operation.
umer0314
Joined Jul 29, 2009
29
I am trying to run it on multisim basically. The circuit you gave when I check the output with a probe at the end of U4 it gives me 0 volts and a lot of other areas too its doing the same thing. I just want to show that pulse train we talked about in a simulation.
