I want to be have a 555 timer that can only be triggered once the discharge cycle is over.
Meaning that i want to trigger the timer, allow it to enable output HIGH (charge cycle) and then on discharge cycle output will be LOW, but trigger must not be allowed to trigger timer till discharge cycle is over.
I know that if you hold RESET (pin 4) LOW, trigger (pin 2) will not be allowed till pin 4 is HIGH again.
I want to design a circuit to hold RESET LOW till discharge cycle is over, then trigger is allowed.
