555 timer self reset.
sghioto
Joined Dec 31, 2017
8,692
I don't have a IRF540 on hand but the circuit worked just fine using a IRF520 mosfet. IRF540 has same gate threshold as the IRF520 so should work. Which circuit did you try?
The correct version is below.
sghioto
Joined Dec 31, 2017
8,692
OK must not be connected correctly.
If you can post a HD closeup of the breadboard I might be able to see why it's not working.
sahil-siwatch
Joined Jan 12, 2021
43
Nicer version using one transistor.
Works in your Simulator.
Can you share your design that you used in simulation?? I made this design and it doesn't work. Nothing happens when I press the button. LED not even switching. convenient thing would be if you can 'save as' your simulation and share link.
edit : it works. I forgot to attach battery :D sorry. thanks again :)
Thanks and Regards
