555 timer self reset.
Ian0
Joined Aug 7, 2020
13,248
I was a real pain. The product was designed based on the Philips (HEF) Datasheet. Only when we had bought a batch of SGS-Thomson parts (HCF prefix) did we find that they were different, and from then on we had to check every quote to make sure that the supplied had not substituted parts from a different manufacturer, especially when all the other 4000 series was "don't care" as far as manufacturer was concerned.
sahil-siwatch
Joined Jan 12, 2021
43
It is possible using a 555. Here's a version that requires 2 additional transistors.
Keep in mind it only works with brief pushes of the switch.
hello. Thanks for the help. This circuit resets the timer. When I press the button i.e led starts glowing from t=0. I want to switch off the led on second button press. Maybe I am doing something wrong. here is screenshot to my simulation circuit.
sahil-siwatch
Joined Jan 12, 2021
43
That's not how my circuit is drawn. I have no connection on DIS or THR. What's the purpose R1 and C3?
It will decide the time of the output of the monostable timer. In your circuit, How will you decide the time for which output will stay 'HIGH' when you press the button ?
sghioto
Joined Dec 31, 2017
8,749
I apologize I did not read your first post correctly. I now see you want the circuit to shut off after a certain amount of time
Then reconnect as before.
sahil-siwatch
Joined Jan 12, 2021
43
yes. but that's not working. timer gets triggered but not resetting.I also asked here . got some solutions. tried them. NO success. still trying
