555 Timer monostable help needed
eetech00
Joined Jun 8, 2013
4,724
What do you think it will do?
It will delay the trigger by the RC time constant (4.7s) at the input. If the input pulse is short (say 200ms), it will still add the RC time, which is not what I think the requirements state. It should only add the timer timeout upon recovery of the HMI signal.
Ian0
Joined Aug 7, 2020
13,279
Hence the diode and 100 ohm resistor, which gives a 4.7ms time constant on the start of the pulse.
So, output pulse starts 4.7ms after the start of the trigger and ends 4.7s after the end of the trigger.
eetech00
Joined Jun 8, 2013
4,724
1 RC=4.7 seconds
It will take about 1.8s to reach 1/3 Vcc of 5v
The only issue I see is the output will be high on power up since the trigger will be initially low.
