All in parallel. A single LED will need a maximum forward voltage of 2V at 50mASome combination of parallel or series+parallel.
What current do you want for each LED? What voltage are you operating the timer at? What is the forward voltage of the LEDs?
A bipolar 555 timer can sink/source about 200mA. If you need more, you can have the timer drive a MOSFET.
What voltage is the timer operating at? You'll waste less power as heat if you can do series+parallel.All in parallel. A single LED will need a maximum forward voltage of 2V at 50mA
