555 Timer for 10 LEDs
Khisraw
Joined Nov 14, 2020
56
I am using 555 Timer on astable mode to generate a 38Khz frequency for an IR LED. It might be a simple question but does anyone know how LEDs I can drive (All at the same time) with a single 555 Timer?
dl324
Joined Mar 30, 2015
18,326
Some combination of parallel or series+parallel.
What current do you want for each LED? What voltage are you operating the timer at? What is the forward voltage of the LEDs?
A bipolar 555 timer can sink/source about 200mA. If you need more, you can have the timer drive a MOSFET.
Khisraw
Joined Nov 14, 2020
56
All in parallel. A single LED will need a maximum forward voltage of 2V at 50mA
dl324
Joined Mar 30, 2015
18,326
What voltage is the timer operating at? You'll waste less power as heat if you can do series+parallel.
With a 2V forward voltage, operating 2 in series with a 5V supply would give a current limiting resistor of 20 ohms.
What is the maximum continuous and peak current spec for the LEDs?
Ian0
Joined Aug 7, 2020
13,131
If you are not using pin 7 (discharge) as part of the timing circuit then it can drive some LEDs as well as pin 3, until you reach the maximum for the negative power supply pin.
Wolframore
Joined Jan 21, 2019
2,619
Most of the IR LEDs I’ve used have much higher current rating than similar red LEDs. I’ve seen specs around 100 mA or more (continuous)... why not just use the output of the 555 to a transistor which can sink more current.
bertus
Joined Apr 5, 2008
22,922
What will be the purpose of the circuit?
If it is an IR jammer, we can not allow the circuit:
Bertus
