555 Timer Circuit to set time for 15 seconds with 2 second intervals
Damien De Silva
Joined May 20, 2017
29
Hello Everyone,
I want to make a timer from a 555 timer. It should be able to set the timer for max 15 seconds. It should also be able to set times with 2 second intervals until 15 seconds. Monostable 555 timer design. I want the circuit diagram and way of finding the resistances.
Thank you Everyone !!!!!!!!!!
Great Help.
Damien De Silva
Joined May 20, 2017
29
I checked the data sheet but I am not comfortable in drawing the circuit on the data sheet using multisim. Is there any way I could find a simpler circuit diagram that is more easier for a beginner.
Bernard
Joined Aug 7, 2008
5,784
How do you wish to select the time ? Rotary switch, electronic switch as 4017, 4066 ? Timing is close to just RC . Start with a 1 M pot & 20 uF, adj. to 15 s, measure, replace with fixed value. 2 s will be about 100k .
Damien De Silva
Joined May 20, 2017
29
I want to use a rotary switch to set times."Start with a 1 M pot & 20 uF, adj. to 15 s, measure, replace with fixed value. 2 s will be about 100k ." can you explain me this part a bit more. can u label which circuit component should be replaced with 1 M pot and a 20uF capacitor on the picture I sent before.
Bernard
Joined Aug 7, 2008
5,784
Large capacitors generally have a wide tolerance, like +_ 20% so calculations will just get you in the ball park.
I don't have a 20 uF but have a 22 which is really 23.4 uF @ 10 M ohm leakage. Leakage may change with use so soak it ( apply a V ) for awhile before selecting Rs. On your drawing, replace C with 20 uF & R with 1 M pot in series with 1k R.
Damien De Silva
Joined May 20, 2017
29
Ok thanks I'll try it. BTW I want to change the times to 15,10 and 5 minutes.
38,604
From seconds to minutes?
Those times are too long to reliabily do that with just a 555 by itself.
You could use a higher frequency 555 astable into a counter.
For example a 0.25 minute astable going to two CD4017 decade counters configured to divide by 20, 40, and 60.
AlbertHall
Joined Jun 4, 2014
12,637
But then you might as well use a CD4060.
AlbertHall
Joined Jun 4, 2014
12,637
True.
But you need some added decoding logic to get the desired time delays which the CD4017 doesn't need.
True, but only if accurate timings are required and they aren't going to be all that accurate using an RC oscillator.
[Thinks..]
With the '4060 you could switch different capacitors or resistors (and pots to set the individual times if you wanted) in the oscillator then no extra logic is required.
