Circuit for flashing led for 10 seconds after pressing a button using 555 timer
GreenBird
Joined Dec 20, 2021
10
Hi, I need suggestion / circuit diagram for flashing led for 10 seconds when i press a button and release it. I thing using 555 timer IC, it can be done.
Kindly respond to this thread, Thanks.
sghioto
Joined Dec 31, 2017
8,756
Use two 555 timers or one 556. First timer is set up as a 10 second one shot that activates the second timer which flashes the LED at the rate you require.
Oh yeah forgot to ask, Is this homework?
dl324
Joined Mar 30, 2015
18,478
Welcome to AAC!
These modes of operation are described in detail in the datasheet. Do you want to try to do it yourself?
eetech00
Joined Jun 8, 2013
4,733
Here is an example. The Astable Ton is about 0.5 seconds. See below.
If the LED stays on (in your circuit) it might be because the Astable frequency is to fast.
38,869
Below is the LTspice simulation of a circuit that should do what you want using one CD4093 quad Schmitt-trigger NAND-gate package, and a transistor to drive the LED.
Closing PB1 to ground (green trace) starts the pulses.
U1a generates the Gate signal ON time period (red trace).
U1b is configured as a relaxation oscillator (yellow trace).
U1c is used as an inverter.
I(D1) is the LED current (blue trace)
R3 & D2 set the initial voltage at RC to about 1/2Vdd, otherwise the first pulse would be about 2.5 times longer than the rest.
R4C1 determine the ON time, and R2C2 determine the pulse frequency.
Edit: Added U1d to form a latch that keeps the Gate signal high until the last pulse is complete, which avoids the possibility of otherwise truncating it.
GreenBird
Joined Dec 20, 2021
10
Closing PB1 to ground (red trace) starts the pulses.
U1a generates the Gate signal ON time period (blue trace).
U1b is configured as a relaxation oscillator (green trace).
I(D1) is the LED current (yellow trace)
Thanks a lot
Rich2
Joined Mar 3, 2014
254
You can make a short timer with a capacitor and single transistor, you could then use this to power a flashing type LED. I made a 13 second timer like this last year.
