555 TIMER CIRCUIT DESIGN
BBGIRL
Joined Jul 27, 2022
5
I am trying to develop the circuit based on the input signal 10ms clock period signal, and the duty cycle I gonna use is 10% or 20%, which indicates if a user presses a button in the remote controller or not. When the duty cycle is 10%, the designed circuit output constant 0V; while when the duty cycle is 20%, the designed circuit generate another 10ms clock period signal with duty cycle 60%. I am thinking of using 555 timer but don't know where to start can someone guide me on this?
38,740
Here's the LTspice simulation of a 555 circuit that I think does what you want:
Note that the circuit is sensitive to the RC time constants, so some tweaking of C1, and/or R1 and R3 may be required for proper operation, depending upon how close to a 60% output duty-cycle you need.
BBGIRL
Joined Jul 27, 2022
5
Thanks for the guidance. I tried out the design with LTspice simulation but for some reason, I am getting 5v at the initial stage. And can you explain how did you give the input pulse signals values?
BBGIRL
Joined Jul 27, 2022
5
And how did you find the value of Capacitors and Resistors? is there any formula?
38,740
I have no particular formula, but you could certainly calculate them using the exponential charging equations for RC circuits based upon the known trigger threshold voltages of the 555 (1/3 V+ for Trig and 2/3 V+ for Thrs) along with the signal characteristics, however I just adjusted them in the simulator until the desired output was achieved.
BBGIRL
Joined Jul 27, 2022
5
You could certainly calculate them based upon the known trigger threshold voltages of the 555 (1/3 and 2/3 of V+)
and the signal characteristics, but I just adjusted them in the simulator until the desired output was achieved.
Do you know why my initial output started at 5v even though I followed your design?
38,740
Not sure, but you are not using the same 555 model as I used (mine is a transistor-level model, while yours is an idealized).
(Note that your simulation shows an ideal 5V output, whereas mine is about 4.7V).
There is an initial transient that gives an output high, which occurs when circuit power is first applied (would that be a problem?).
The transient is due to the time it takes for the Trig voltage to charge up.
This can be prevented if C1 is connected to V+ instead of common.
Below is a simulation of the modified circuit, without the initial Spice DC bias calculation to show the power-up transient:
ci139
Joined Jul 11, 2016
2,026
http://beta-tools.analog.com/timerblox/LTC6993
inputs : Voltage Controlled /// Supply 5 /// Div code 3 /// Pos. Pulse Min.(s) 800u Min. (V) 0 /// Trig. Rising Edge Max (s) 1200u Max (V) 5 /// Non-retriggerting
the button press can be communicated to VC input
Update : it seems i misread the desired function of the circuit
