Hello All,
I'm trying to convert direct dc to pulsed dc. Here goes the method I used so far for conversion.
First I used 555 timer in Astable mode to generate PWM pulses.(0-100% duty cycle).
These pulses are used to drive the MOSFET's gate. (SiHP6N40D), the output of the mosfet is used to drive electromagnet coil(load).
I got few problems with above circuit:
1) the mosfet output is inverted as compared to 555 output.
2) if I supply 10V to mosfet drain the max vtg read is 12V (CRO measurement). this happens for every increment of voltage eg 11V means 13V it reads)
3) after connecting load I see high voltage spikes at the rising edge of mosfet output, this also causes spikes in 555 timer output.
4) to solve problem(3) I placed a electrolytic capacitor across drain and source, the spikes are removed but there is change in the mosfet output waveform i.e the low state seems to be discharging of capacitor.
5) the mosfet is rated for 6A current handling capacity. the mosfet is too much heated with supply of 3A of current even though heat sink is provided.
Pls help me out . (sorry for my english)
Attaching the circuit for reference.
Regards,
Priya
Regards,
Priya
