What would be the output of 555 1 second monoshot if I press the triggering push switch for 5 second ?
Here is my circuit...I would rather see your circuit to give you a proper answer.
By my calculations, given a 1.2k resistor and a .82μF cap, your pulse length timing isn't 1 second; it's 1082.4 μS. So, unless you are very quick on the button, the pulse will be equal to the length of the button press.Here is my circuit...
Don't worry about OPAMP and transistor, now we discuss about output at 3rd pin of 555.
