555 Circuit somehow grounded
sghioto
Joined Dec 31, 2017
8,750
Connect the switch to the reset pin. The reset pin discharges the cap if pin 6 is tied to 7. Transistor not needed.
The reset pin overrides the trigger pin.
That's not how the circuit was originally intended. The circuit was designed to monitor a closed switch. As long as the switch is closed the output of the 555 remains high or alarm OFF. If the switch is open for a period longer then the timing cycle then output low, alarm ON until the switch is closed again.
SG
SamR
Joined Mar 19, 2019
5,535
Latest iteration. C1 upped to 68u to slow down charging and 1u pin4 to GND for startup suppression.IMG_0369.JPG
SamR
Joined Mar 19, 2019
5,535
SG
Or if it is open on power up you have x time to close it before alarm is triggered.
SamR
Joined Mar 19, 2019
5,535
No it isn't, and Mins described it as I stated, starting sw1 open and closing before x timed alarm.
Working on 555 test ckt. My notes for monostable show pin6 and 7 jumpered?
sghioto
Joined Dec 31, 2017
8,750
First off Mims is wrong in this particular circuit. This is not the first time I have seen his circuits drawn incorrectly.
Two mistakes: pin6 connected to pin7 and omitting a .1uf cap from pin2 to ground.
Your diagram of a 555 monstable is also incorrect.
SG
SamR
Joined Mar 19, 2019
5,535
I'm not surprised about Mims since I had another of his circuits that we wrong, When powered LED immediately lights and 0V on pin6 with sw1 closed. And I added .1uF to pin2 to GND. Will work on my notes later to build chip test circuit.
eetech00
Joined Jun 8, 2013
4,724
Nevermind how Mims version works....how do YOU want it to work?
eT
eetech00
Joined Jun 8, 2013
4,724
SG
I get it sghioto...I was just describing how the 555 works..
eT
SamR
Joined Mar 19, 2019
5,535
eT
The idea was to intervene and prevent an event failure alarm. That has morphed into a 555 timer issue since was using timer to delay the failure alarm.
sghioto
Joined Dec 31, 2017
8,750
SamR you must have a bad chip and this would not be the first time after that incident with the LM311.
I bread boarded the circuit and it works as described in post #21.
SG
SamR
Joined Mar 19, 2019
5,535
I had 7 NE555P and 1 was bad. I had already swapped 1 timer and things got confusing testing so not sure which one was on the board. Put good timer on board and OV at pin6 and 4.45V on pin OUT.
The monostable test calculated for 5.12 seconds which it did.555-monostable-test-ckt.png IMG_0370.JPG
SamR
Joined Mar 19, 2019
5,535
Current iteration and original Mims sketch. Note that Mims had this for a 9V battery supply and I am using 5V bench PSU. I replaced the noisy active buzzer w/ a LED. Yes, this is the msg#8 config.
