555 circuit not Flashing
AlbertHall
Joined Jun 4, 2014
12,637
connection between pin 2 and 6 good.
OK, can you try a 10uF timing capacitor? Perhaps pinching the one from pin 5?
The leakage of the 1000uF may be too great.
If that doesn't give you flashing then please post a good picture of your circuit that will let us follow the connections.
gfvesley
Joined Nov 4, 2017
18
Check the connection between pins 2 and 6.
Problem solved. Rebuilt the circuit using a new capacitor and a new 555 chip from a different package. LED flashed, however slowly, about 6 seconds. Flashing rate increased be changing capacitor. Apparently capacitor or chip were shorted. Thanks for your help.
George
gfvesley
Joined Nov 4, 2017
18
Is there to test a 555 to determine if working correctly. Made a circuit, worked. Tried to change flashing rate by changing R3. Burned out LED. Changed LED. Only lights, does not flash.
dl324
Joined Mar 30, 2015
18,437
You build a test circuit; just like the manufacturer would do.
If you make an astable, the only other function to test is reset. If you want to do parametric testing; that would be more involved.
gfvesley
Joined Nov 4, 2017
18
The circuit flashed. I changed value of R3. The flashing rate changed. Went to a lower value of and burned out LED. Changed LED and made R3 bigger. LED lights but does not flash. What changed? The only thing I see is something changed in 555. Why dose't it flash?
dl324
Joined Mar 30, 2015
18,437
Changing R3 would not change the flashing rate.
What did you change R3 to?
To see if the timer is working, you can measure the capacitor voltage to see if it's changing and alternately charges to 2/3VCC and discharges to 1/3VCC. You can also monitor the output to see if it's changing; it should alternate from near ground to near VCC.
The output can source 200mA (assuming you're using a bipolar timer), and it should have been able to destroy an LED without being damaged.
Are you certain the replacement LED is functional and connected correctly?
gfvesley
Joined Nov 4, 2017
18
Which R changes the rate?
I reduced R3 to 100 ohms. Still flashed. rate a little quicker. R3 10 ohm burned LED. Tested LED with battery and resistor. No good.
Cap measured at 94uf. Input V and V across cap same. Cap not charging but measures OK.
absf
Joined Dec 29, 2010
1,968
You're risking the life of 555...
Datasheet says the Max Vcc for Bipolar 555 is 18V and cmos is 16V.
The NE555 is about the same... See datasheet attached
gfvesley
Joined Nov 4, 2017
18
Why would the circuit flash for a day or so and the failed when I changed the value of R3? I thought RC was the time. Does R2C change rate? Which way? Increase R2 lower rate or increase rate? I am trying to understand this circuit.
