Hello guys,
Im building a Counter using a 4510 Decade Counter to count from 0 to 50 in 2 7 segments. Now the problem that Im having is that I want to be able to perform the counts manually and automatically. I built 2 555 circuits, one astable that gives me a 1 sec clock and the other monostable so when I push a button, it produces me a clock to get the counter up or down. Im using a 2 position switch with 3 pins. At the ends I have the 555s and in the middle of the switch i have the cable that goes into the 4510 circuit. Works fine, but here is the "problem" If I have a number in display and switch from manual to automatic or the other way, if the movement of the switch its slow, the counters go crazy. Is there a way to fix this?
I tried to put both circuits to the same pin in the counter but does work, it does nothing in the counting. I also put 2 diodes at the end of each 555 so one signal doesnt bounce back to the other 555, but the 4510 goes wild also.
Any other Ideas?
Best Regards
Any other Ideas?
Best Regards
