50Hz with N mosfet : ltSpice transformer problem
j4e8a16n
Joined May 1, 2013
44
Hi everyone,
I made this LTSpice file for testing this 50Hz oscillator inverter
I found a transistor model but I dont see why it does not output a wave.
I used the following formula for the frequency = 1/( .7 * Rbase *C)
Regards,
JPD
Alec_t
Joined Sep 17, 2013
15,156
...... also note that the 2N222s will fry because the negative-going voltage on their bases exceeds the base-emitter junction breakdown voltage.
ericgibbs
Joined Jan 29, 2010
21,569
hi j,
It is usual to fit clamp diodes from the Bases to 0v, so the Vbe reverse does not exceed -0.7v
But this may effect the osc frequency, it is a poor design.:(
E
