I am working with an analog video to analog video encoder (RGB > YPbPr / Svideo / Composite, the BA6592F) and having some difficulty. The encoder asks for a pulse I don't have.
The encoder expects a pulse that the datasheet refers to as 'pedestal clamp' and I have a rough idea of what it does. Judging by the timing chart it seems to be identical to the burst flag pulse, which I also do not have. What I do have is a Horizontal Sync pulse (normally high, active low). So what I have been trying to do is to fork the sync pulse, and then run a shortened and delayed version of that pulse into the Pedestal Clamp pin. This would require delaying the falling edge by 5.3 microseconds (and shortening the pulse by 2.2 microseconds, which I believe I can do with a carefully selected capacitor to ground through some kind of equation).
I have attempted to use an LTC6994-2 for this, but I... couldn't really figure out how to use the chip, even after using their spreadsheet tool. I assume that it failed because I'm dealing with a normally high, active low pulse.
All of my video timing assumptions here come from Maxim Integrated's chart here:
https://www.maximintegrated.com/en/images/appnotes/734/DI39Fig05.gif
For all intents and purposes, the sync tip is the Horizontal sync pulse I've been talking about. Pedestal clamp pulse and burst flag pulse would both be active during the colorburst section.
That's about as far as I've gotten though. I can't find any analog delay lines that are the right length (or would be affordable if I were to place several in series). Is there some kind of small device that can accomplish this delay, or a way to build it?
It's worth mentioning that I'm not positive about my timing requirements, so the better I understand this the more I can fiddle with it... Any words are appreciated, because I'm all out of ways to google this one.
