4PDT Relay/help/diagram
djsfantasi
Joined Apr 11, 2010
9,237
ok so I m not understanding in the diagram above..
.is that a 4PDT?? OR??
can you possibly put pin #'s o on the drawing?
IM SO SORRY BUT IM LOST
It’s not a 4PDT switch. It’s a DPDT switch. I’d get a center-off switch or a break-before make. It’d still be a DPDT switch, but just a special type.
The center pin is usually the common pin and goes to the motor. Each power supply goes to the pair of pins on each end.
sghioto
Joined Dec 31, 2017
8,763
I have 2 110v sensors that may call for the motor to activate at the same time. this is why a relay or relays are required to prevent BOTH from trying to power motor at the same time.
I see a couple of options. First option uses a single DPDT relay and allows only one sensor to power the motor at a time but gives priority to one sensor only (either sensor 1 or 2).
Second option uses 2 DPDT relays and gives priority to which ever sensor activates first.
