40Khz ultrasonic transducer power adjustment?
smilem
Joined Jul 23, 2008
162
Hello, the usual 40Khz ultrasonic transducer power is 50W. For some applications this can be too much.
Can I use 40Khz ultrasonic transducer power MJL1302AG wtih resistor to controll the amount of power going to the transducer. I know I can use a POT but that requirs some 150W POT. It is more easy to use transistor. But will it not interfere with frequency and the circuit is auto adjusting for oscilation. So with the transistor it will work?
ericgibbs
Joined Jan 29, 2010
21,567
hi smilem,
What is the power supply voltage to the transducer drivers and are you able to control/reduce that voltage.?
E
ericgibbs
Joined Jan 29, 2010
21,567
hi smilem,
Do you have a Scope.? to display the waveforms at the transducer.
Also a circuit diagram of the project that you could post and how are you going to use the project/application.?
E
E
