4 output rotary switch for a rca video mixer? Degree project
Alexlee
Joined May 11, 2017
7
Im putting together a design project that involves switching 4 video inputs between 4 TVs, using rca video cables.
Is there a rotary switch I can buy that I can connect the 4 inputs to one output?
Or
I have in the past built a 'dirty mixer' using a potentiometer and 2 rca video inputs, so the signals mix as you move from one input to the second. Is there a potentiometer that could take 4 inputs?
Any advice would be much appreciated!
Al
#12
Joined Nov 30, 2010
18,224
Another way to do it is to use the switches to switch DC voltages and switch the video inside integrated circuit chips. If you get into trouble with losing signal quality, you will end up using switching chips.:(
