I am a maintenance technician at a coal fired power plant. I would like to be able to test control valves after I rebuild them. It would be great if I could build a circuit that would generate 0-20ma or at least 4-20ma into varying loads no greater than 1000ohms.
I am aware that this would require a (relatively) high voltage and am therefore going to be utilizing three 9volt batteries for a total of 27volts. I am aware buck/boost converters exsist and may utilize one of the ready made ones on ebay if I get the basics working first.
I have tried the following circuit from the LM317LZ datasheet (page 5) however I have been unable to achieve currents lower than 13ma without dropping input voltage which is undesirable because I would like to utilize one pot to adjust the position of the valve which corresponds to the 4-20ma signal and it is desirable to utilize the entire range of the pot no matter the load resistance.
This group on this forum and especially the moderators have what seems an infinite knowledge of electronics. Is there some sort of ohms law or current divider concept I have totally missed? I would like to have the simplest circuit possible and no chance of sending greater than 20ma to the I/P in the valve. I have 10 lm317l and many other components at my disposal.
Robert
Robert
