4-16 bit decoder
The_Cook
Joined May 29, 2014
48
Trying to create a 4-16 bit decoder with 4-bit input, 16 output signals. I think this is correct, can anyone verify:
33,118
Do you want the outputs to be active-HI or active-LO?
What steps have you taken to verify the correctness of your design?
33,118
Doesn't matter if it is active-hi or active low for this one.
So it doesn't matter if the outputs are correct or not?
What would you suggest I do to verify?
Derive the functionality (equations or truth table or whatever) from the diagram and compare that to the function the circuit is supposed to implement.
