HI,
I want to make a 40 X 3W led array (28 Red, 5 Blue, 5 UV, 2 Green) ,
35 of the LEDS has a forward voltage of 3.6V and other 5 UV Leds are 3.2-3.4V. All of the LED's max currrent is 700mA.
I want to make the array 10 leds in a series string and 4 sets of series strings in parallel.
Each 10 LED series string has 9 x 3.6fV LED's and 1 x 3.4fV LED's. Is it possible to run the different forward voltages together at 35.8V per string?
The power is coming from a 38Vdc power supply to a 5A buck module.
When i try power each string at 34-35.8V 600mA. Im finding the ends are bright but some are dim and few not working, (which are the 3.4v ones and some 3.6v ones). The String seems to flicker on and off,sometimes all the LEDs in the string,sometimes only a few.
If anyone is able to assist, id be very appreciative.
