3v-9v variable dc from 12 dc
360smokers
Joined Dec 2, 2013
1
Hi Sir I would Like to get variable voltage starting from 3 V to 9 VDc, With an input of 12V Dc. With 4 Amp Current limit. If you could provide me with schematics with excellent efficiency It would be really helpful to me. Waiting for your reply
Deepak Kamble
bountyhunter
Joined Sep 7, 2009
2,512
No, BH, Figure 47 on the datasheet is exactly what the OP was asking for. A very elegant solution to create a switching supply from a LM317.
Figure 47. 4A Switching Regulator with Overload Protection​
OK. Looks like something the marketing guy dreamed up after a five beer lunch. I would not use it for a variety of reasons, like there are much cheaper and easier ways that wouldn't be so large with so many parts.
Still can't believe you can buy a 100W DC-DC converter complete for $12 on ebay, but you can.
tindel
Joined Sep 16, 2012
939
After you questioned the circuit I did some spice analysis... the regulation on this thing sucks... I agree with BH's suggestion to use a dedicated switcher... unless someone can see something that I'm missing. There are many chips available on the market... everyone makes several, and you can buy them on fleabay for a few bucks as already discussed.
I did just suggest it based on simplicity of using a linear regulator... but the circuit is pretty complex. A dedicated buck switcher will work better.
I am curious if anyone can see a way to improve the regulation of this circuit though... maybe I'll learn something.
MikeML
5,444
To make it behave better; but still not as good as a modern switcher chip:
Reduce the series resistance of the input supply V1, or reduce the esr of the input capacitor C1.
Reduce the Inductor L1 to 60uH, probably means that it is switching too fast.
Increase the capacitance of C6 to 1uF
Reduce the esr of C4.
tindel
Joined Sep 16, 2012
939
Hmmm... tried all of those things (with the exception for C6 - I didn't have a C6 in my schematic) - the step load response did not improve to usable levels.
