380VAC Transformer for tube amp
NotBigfoot
Joined Aug 6, 2014
7
I am building a 5W tube amp (Octal Fatness)
Now my question is what kind of transformer i would need for this amplifier (i live in the netherlands so primary is 230vac)
And where would i purchace this transformer?
Thanks in advance!
Nick
Veracohr
Joined Jan 3, 2011
783
Looks to me like you would want about 357V on the secondary, considering the point after the diodes is 356V.
Regardless, I don't know where in your country to buy transformers, but they typically are specified by secondary voltage rating and current. You need to figure out how much current it will require.
NotBigfoot
Joined Aug 6, 2014
7
Yeah the switch is in a strangr place, ill probably place it in front of the transformer.
But im looking for a model of transformer that will suffice (if possible), or maybe even a webshop where to acquire the transformer
Thanks!
NotBigfoot
Joined Aug 6, 2014
7
I've decided to build my own transformer because i cant find one with the right specifications for a reasonable price.
Now my question is:
Where can I order a transformer kit?
or
Where can I order the parts I need to build the transformer?
Thanks in advance!
Nick
mitko89
Joined Sep 20, 2012
127
I was working in a company that was specialized in design and manufacture of transformers. If you provide some specification I can give my man there a call and ask him how much would it cost. I am not sure I am allowed to provide the site of the company. If you want to know it write me a PM and check it yourself.
22,099
I've never heard of a transformer kit. There are two approaches you could take.
  1. Locate a suitable torroid core
  2. Fabricate a core from multiple pieces of sheet steel
Once you have a suitable core you use enameled magnet wire to wind the transformer. Then comes testing and finishing.
34,988
There are transformers and there are transformers.
Tell us what you want to transform with numbers, voltages, currents, wattage, frequency.
kubeek
Joined Sep 20, 2005
5,796
Saying in which country would be helpful. There are a lot of companies that will make it for you, and a 20W should be pretty cheap.
30,764
If in N.A. you could pick up a Toroid from Antek (Jonango on ebay) that has the closest specs, this will already have the primary and you can either add to or remove a secondary winding to increase the particular voltage you need.
Also small aux windings can be added if needed.
I see you are in Europe so look for a Toroid manuf there.
alfacliff
Joined Dec 13, 2013
2,458
checkout "control transformers" I am not too sure of the european standards, but here we can get control transformers for industrial use pretty reasonable and from 5 to 5000 watts or more.
