380VAC Transformer for tube amp
KMoffett
Joined Dec 19, 2007
2,918
seems like a strange place for the switch.
I've seen this in a CRATE guitar amp that I'm working on for a friend. It's a "Standby" switch. The "Power" switch is in the primary. The Standby switch is turned on a while after the Power switch. With a single power transformer, this lets the heaters warm up before applying plate and bias voltages....as I've been told.
Not sure I trust audiophile design logic.
Ken
GopherT
Joined Nov 23, 2012
8,009
Ken
The standby switch seems to minimizes hum during the first few seconds of warm up. Mostly a Simply way to turn off the output when gear is moved around at a concert. My son just flips both at the same time for home/personal use. I don't quite see the point for a 5W practice amp in this case.
kubeek
Joined Sep 20, 2005
5,796
IIRC applying HV to the anode before the cathode has heated up will strip off electrons off the cathode and damage the coating on it.
