Newbie, so thanks in advance...
Problem: One of these: Controller
From a 30 amp night storage Aga, replacement costs £950 or £250 for repair.
Purpose: to control elements that heat the brick core of a night storage Aga to approx 700 degrees on cheap economy 7 power, air is then circulated around the oven to maintain oven temperature for cooking. Main board takes input from core thermocouple and oven thermocouple to power the 3 ganged relays for the heater elements.
Symptom: board powers up, energises relays and then turns them off again, does this rapidly until fuse blows, relay board fails or essex thermostat trips out or all of the above!
Have replaced controller with a second hand one off eBay (£320) and Aga now works, but I would like to fix the original to keep as a spare (spent too much on the aga already).
Looking at images of other controllers, and the replacement unit I can see that the Mosfet MAR839 has been replaced (centre top of board with heatsink).
So far so good, but has anyone any experience of fixing these boards and is there likely to be other components that cascade fail with this one?
Many thanks to all in advance...
