Hi everyone
I have a 3 speed fan that's controlled by a 3 way switch i want to remove this switch or leave it but also use 3 separate switches/sensors/timers, as you can see from my bad drawing if i wire it like that and have the 3 switches or tigers on at once it'll try turn on all 3 speeds together,so i need to wire relays in so when one speed is selected the other 2 cant be, everything is 230vac, thanks in advance for any help.
