3-rail AC — O Gauge Model Train Wiring
JimAspin2
Joined Feb 4, 2020
The track runs at 18VAC. I’d like to place an LED on a box car that runs on 5VDC. Can anyone share a circuit that would do the job?
38,832
A diode with a filter capacitor to common (or a diode bridge), and a resistor in series with the LED should work.
What's the type of LED and how much current?
Reloadron
Joined Jan 15, 2015
7,952
Most O Gauge trains locomotives run between 8 ~ 10 volts slow and 18 volts is maximum from the transformer. The track voltage is variable. I would just grab the track voltage, rectify and then maybe toss in a 5 Volt regulator so any changes in track voltage would not change how bright your LED is. Either a 5 volt regulator or a 5 volt out buck converter. Both are inexpensive on Amazon or other hobby outlets. This only if the track voltage varies when varying locomotive speed.
Ron
Reloadron
Joined Jan 15, 2015
7,952
The only DC train sets I recall were the HO Gauge and back then I recall the power supply being called a power pack. They were about 0 to maybe 15 or 16 VDC since there was no PWM at the time. All of my O gauge stuff was AC powered and I think somewhere in the basement is an old O gauge American Flyer transformer. Anyway when the thread starter returns I would be curious if the rail voltage changes as the train speeds up or slows down?
Ron
djsfantasi
Joined Apr 11, 2010
9,237
Ron
The rail voltage does change. The old Lionel power packs were an 120VAC to 0-18VAC variac. Besides the variable AC, there usually was a fixed AC tap for accessories.
Reloadron
Joined Jan 15, 2015
7,952
That's right. Wow been a few years since my model train days, I wish I still had those trains. Things like switches had a fixed voltage.
Ron
Reloadron
Joined Jan 15, 2015
7,952
you simply make a center rail wiper out of some brass spring stock. Or get a replacement part catalog and purchase a center rail wiper. Several Lionel cars use one, such as the searchlight car.
That would work. Could likely fabricate something from a wall anchor & bolt with some creativity.
Reverse it and put some contacts in the wings.
Ron
shortbus
Joined Sep 30, 2009
10,049
I don't understand that. If you reverse the wings they are solid, so why not just use the head of a screw? I would think you would want the spring loaded wing to allow so give to go over the track joints, reversing the wings doesn't allow that. Or am I missing something?
AlbertHall
Joined Jun 4, 2014
12,653
You would probably also need to round off the ends of the wings so it doesn't catch on the joints of the centre rail when travelling backwards.
Reloadron
Joined Jan 15, 2015
7,952
I seem to remember little rollers so I thought about making small brass rollers. This all short of hacking a part off another part of the train(s). I really don't know but getting creative can be amusing.
Ron
Tonyr1084
Joined Sep 24, 2015
9,744
I was but a child when I had an O Gauge train. I hated that when you started moving sometimes it would go forward and other times it would go backward. There was an interrupt button you could interrupt the power momentarily and take a 50/50 shot at making the train go forward.
As for a center contactor - I think back to the days with slot cars that had braided wire brushes to contact the track. They had a habit of wearing out, and finding replacement brushes was not easy. I discovered that shielding from an old coax cable could be used as a brush. Strip a bit and stick it into the holder and off you went. So for a center wiper - perhaps a braided shield stripped and removed from a coax cable might be a consideration as an alternative for a center contact.
I don't remember if the trains I had were powered from both outside rails or if the center rail provided a common point and either outside rail completed the circuit. Gosh, that's been such a long time ago. Then I went with HO scale. I now have an N scale train down in the basement with dreams of one day setting it up on a board. However, simply setting it up on the kitchen floor to play with the grand children often proved difficult because the track contacts were not very good. The wife had (I have it now) a sponge with sand paper on three sides for sanding and polishing nails, three different grades and I use that to brush up PCB's before soldering to brighten up the soldering surface. I've used it to brush the tracks as well, but still find it difficult to get good contact with the N Gauge trains.
Also, I've never liked the "Power Packs" they provide, the cheap ones anyway. The more expensive ones that have realistic start off and slow down features were pretty interesting but I never bothered to spend the money to get such a power pack. I think if I ever go back into the hobby I'd probably build my own power supply, using (likely) a transformer and an autotransformer. The transformer to drop mains to a usable power level and the autotransformer to control speed. A switch to control direction.
Back in 2017 I was in Milwaukee during a train festival. I saw trains that were (I think) computer chip controlled with bluetooth to receive commands from the operator. Saw a DC HO scale train that had a center rail. It could go forward on the same track, meaning you could have a single length of track between two loop backs. Regular HO scale trains - that would result in a dead short.
38,832
When I was a kid, I had a Marx 027 train set.
It bugged me that the train would significantly slow down on the opposite side of my (simple) layout due to track resistance.
After some thought I had the idea of making one connection from the controller to the near side, and then run a single wire to the opposite side for the other connection.
That meant the track resistance to the train was fairly equal no matter where the train was, and it then ran at essentially the same speed everywhere on the track.
