3 Phase System - Input Power and Input Current calculation
mishra87
Joined Jan 17, 2016
1,063
Hi All,
Sorry for asking silly question.
I want to calculate the input power and input current for forward converter.
Specification :
Output Power : 80W
Efficiency : 80% Assuming.
Line Voltage : 230Vrms (assuming single phase line voltage 230Vrms)
Papabravo
Joined Feb 24, 2006
22,116
Hi All,
Specification :
Output Power : 80W
The first order approximation would be output power divided by efficiency.
\( P_{IN}\;=\;P_{OUT}/\text{Eff}\;=\;80\text{ watts}/0.8\;=\;100\text{ watts} \)
Does that make sense?
mishra87
Joined Jan 17, 2016
1,063
Hey...Thanks for reply !
yes, this makes sense.
Now lets say L1 = 230Vrms
L1-L2 = 230*1.73 = 398V
L1-L3 = 398V
L2-L3 =398V
In this case how to calculate the input current ?
Papabravo
Joined Feb 24, 2006
22,116
L1-L3 = 398V
L2-L3 =398V
I'm not that familiar with 3 phase calculations but there should be an RMS current, that when multiplied by 230 Vrms gives a power of 100 watts. Could it be approximately 0.435 Amperes(rms)? Probably not, but you need to run that down.
mishra87
Joined Jan 17, 2016
1,063
Thanks for your participation !
Looking forward some expert to jump in to the thread who has experience in 3 phase system.
Thanks !
Ian0
Joined Aug 7, 2020
13,248
IF you have a standard 6-pulse rectifier, then you will get a bus voltage of 565V DC, with ripple at 300Hz.
If the input power is 100W then there will be 33W supplied by each phase, so each phase current is 33W/230V = 0.143A at best but the power factor may not be too good.
mishra87
Joined Jan 17, 2016
1,063
Hey Ian0,
Thanks you so much for joining the discussion !
Yes I have 6 diode for rectification.
