3-8 decoder with 2 2-4 decoder
Leite33
Joined Nov 28, 2015
57
Dear friends.
I looked a lot at google but i cant find a solution. How i can make one 3-8 decoder with (2) 2-4 decoders with out use enable input and without inverse outputs.
Leite33
Joined Nov 28, 2015
57
But my exercise says "Design a circuit that will produce a digit of even parity for a number of 3 binary digit (xyz) using:
a) decoder 2-4 (without using enable input and inverse outputs) and gates OR
33,116
In other words, the problem is NOT asking you to create a 3-to-8 decoder at all!
How would you make an even parity generator for a three-bit input using XOR or XNOR gates?
How would you make an XOR of XNOR gate using 2-4 decoders and OR gates?
33,116
There is nothing wrong with the exercise as you presented it in Post #3:
But this is NOT the same problem that you described in your original post:
These are two essentially unrelated problems. The only thing they happen to share is that each involves 2-4 decoders.
Which problem are you trying to solve?
33,116
Which brings us back to my previous question, but let's rephrase it a bit.
Produce a circuit that produces an even-parity output for a three-bit input using nothing but XOR and XNOR gates.
Do that much first, and then we can worry about using 2-4 decoders and OR gates.
33,116
You will NEED the select or enable inputs for making a 3->8 using 2 X 2->4 decoders.
Actually, you don't. You can use a 2->4 decoder (without enable) to produce an AND gate and to produce a NOT gate. That means that it is a universal gate and that you can implement ANY Boolean function using just a bunch of 2-> decoders. Now, it may not be pretty, but it can be done.
