3.7 volts to 300 volts
Status
Not open for further replies.
ElPapu666
Joined Jul 5, 2017
19
I need a circuit able to amplify 3.7 volts from 5 paralel lipo batteries 1200mAh each, to 300 volts.
¿Has anyone got an idea?
DickCappels
Joined Aug 21, 2008
10,661
There are plenty of ideas, but the question is: Which one is best for what you want to do? For example the best circuit to boost 3.6V to 300V to charge a Geiger-Muller tube is not the same as the best circuit to boost 3.6V to 300V to power an electric motorcycle engine.
Would you please explain what you want to do with the 300 volts, how much current you need at 300 volts, and why you have put so many batteries in parallel?
DickCappels
Joined Aug 21, 2008
10,661
I am sorry but according to the User Agreement we are not allowed to discuss rail guns here.
1. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
◦ Any kind of over-unity devices and systems
◦ Devices designed to electrocute or shock another person
◦ LEDs to mains
◦ Any kind of jammers (ie - Phone jammers)
Rail guns and high-energy projectile devices
◦ Transformer-less power supplies
If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
Status
